loft
  • Thread starter Thread starter Elvis
hello to all, I will be de coccio but as axa says I have to look for in the guide the term "scarta".
I can't find the logic or the right sequence.
Sorry I didn't answer you earlier, but I was out of the internet.
If you happen to have a bit of patience and help me with the sequence I'd be grateful!
elvis
Let's see if I can explain the concept of caramel.
starting from a square or rectangle = 4 sides
you have to get to a circle that theory can be seen without sides or with a "rowned" side where start and end coincide.
it would not be a mistake to create instead of a whole circle, to create 4 semicircles where in substance they sell equated, each circle arc to their side of the rectangle .
in this way the starting point of each circle arc corresponds to the edge of the respective square.
Obviously in selecting the circle you must have the same logic of selection of the square.
Tell me if this is better:biggrin:
