logic nx
  • Thread starter Thread starter Max-C
Max-C
good day and good start week to all,
I would like to ask you a disappointment about how you work in nx in the situations below explained.
hypothesize to have 10x10 square with depth 2.
I would like to create a bow on the component so that the screw can reach a hole below.
in inventor and solidworks I create a hole with distance from the center pairs to 12 (height from center 0) and the hole from 4 (position and diameter of the hole for the screw).
in nx does not let me create a hole if part of it "comes" from the component.
how do you handle these cases? create the extrusion of subtraction?
Hello, it will be that it is early morning but I did not understand a great deal. a clarification: in nx component is a part together, I don't think you meant this. nx also does negative holes.... post an image so I can help you.
I usually solve by making two-year-olds with the prematured supercazzola on the right.... :biggrin:
I'm actually not clear what you should do. better explained:confused:
azz,
how much I regret when I was younger and I came out from the weekend with this mental clarity and synthesis ability:biggrin::biggrin::biggrin:
instead of making the hole with the "normal to face" direction option, do it with "vector".
You won't have a problem.
thanks to everyone for the interest.
I solved with the_matrix- solution
I will see to you a screen with the situation I meant so that you have the solution in this post:)
Thank you so much!
