logistic project of a yard
  • Thread starter Thread starter SalvoP87
SalvoP87
Hello everyone,
I wanted to ask you about how to proceed on revit for the realization of a logistic project. practically I will have to organize a yard, displaying the first step excavations with the foundations, then the first stacked with scaffolding, crane and carpenter, to finish the entire building to the complete.
so I will have more tables in 3d to show the progress of the works.
a first thing that comes to mind, as I will have to make the render, according to you do not want to insert real materials but only colors so as to lighten the render?
Do any of you have any blocks I can pass? (fixed group, construction elements, excavator, etc.)
I accept so many tips so that you start the job properly.
I have a friend who works in this, exactly. he speaks French and English. But I don't know if he understands Italian. if you can translate this message to French and put it to French subforum revitforum.orgI'm sure he can help you. his name is julien benoit. Unfortunately, there is no Italian subforum there.
per
you can use phases. create a do for every period of the project (e.g. excavation, foundations, structures, buffering etc.) or for weeks (depending on what you have to show and cheque to each object of your model the correct phase of creation and or demolition; by duplicating views and correctly assigning phase and phase filter you can check what automatically should be seen; you can do this for all views, plants, prospects, sections 3d, abachi
thanks to the cold. I have registered at the forum, now I wait for reply;)
to use phases. create a do for every period of the project (e.g. excavation, foundations, structures, buffering etc.) or for weeks (depending on what you have to show and cheque to each object of your model the correct phase of creation and or demolition; by duplicating views and correctly assigning phase and phase filter you can check what automatically should be seen; you can do this for all views, plants, prospects, sections 3d, abachi
Thank you so much!... then I will proceed with the steps. I wanted to ask you if you had blocks for revit 2012 (autobetoniera, excavator, scaffolding, barracks, etc.)
go to revitcity.com, register and you will be able to download many yards besides a lot of other things 2d and 3d. I don't know, though, if there is a crane......
