MassiVonWeizen
you dare to repeat the inclusive tooth of band.I extrude a tooth and problems begin when I repeat along the curve.
you must shape the band for its own facts and extrude, then repeat, the only shaped tooth
I don't think I understand what you mean.you dare to repeat the inclusive tooth of band.
I considered the section below the neutra line (which also determines the belt/chain function).Thank you very much, in general very useful command of which I completely ignored existence.
However, I just can't make it work with my proof.
Any ideas? Here is the file con link esterno
I reread the command guide and solved by changing the offset curve method, now I can repeat the function (in this way on the straight stroke the body is unique).you dare to repeat the inclusive tooth of band.
Yes, that kind of handling I get it, too.Have you seen my attachment with couplings and handling?
thanks so much to you for continuous support and ideas of reflectionAlso with 2016 does the same thing, even on my file, at this point I hypothesize is a phenomenon related to the transmission ratio (the next week I try a transmission ratio 1:1 and to set of coupling the exact number of teeth of the pulley).Let's try again.
the movement is there, the tooth does what it wants, but made with 2014 maybe those constraints were not yet optimized. as you see I suspended the mating on the place that is added to the creation of the tooth.
