hello guys I noticed that when I change fonts in the tables and I quote a hole, the "ø" loses formatting, while if I insert it manually it is ok...how come on!? ?
It is not that it does not happen, it happens also to others I would say, but the fact is that maybe you set a font that goes as close as possible as form to that of the hole notes (which should be that of sitema not editable) is then if it is not exactly like chissenefrega, it is not such a big problem (I understand the aesthetic fact, but there is little to do, you have to adapt).
the diameter symbol of the hole/pitch is a symbol of the standard ones and is associated with the arial font. if you use the generic quota you are bound to a font that is usually thaoma (like in the diameter symbol but not perfectly equal): if you change the font, change the symbol more clearly.
