lower level.
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone,
I'm trying to renovate a group but I have a problem, maybe due to the fact that I use this command very little.
therefore.
I have a "a" set ( 4500 celebrations and about 600 parts), consisting of various subaxis.
I would like to bring together some of these sub-assistances in a single set, obviously always considered as a sub-assiem of a" .
I choose in the browser my assemblies to shorten, then ->component
-> lower level and go.
But after the usual message that tells me I could lose constraints etc.etc.
I get an error message that says:
"error in rse clone commander".
I tried to do a "lower level" with another much smaller set and it worked well here, but in this case I used not sub-assis but parts.
Does anyone know what it can depend on or (more easily) where am I wrong?
I have tried to replicate your problem on my set (438 ric, 127 parts, 8 subgroups of which 4 flexible).
the error occurs according to what they select but I have not yet managed to find the logic.
I did it on inv 11 sp4.
the sp1 of the rel.11 cited the resolution of the problem "error in rse clone commander" (sic...)
Bye.
shows if you have selected components in series or mirrored, those in essence that are not "free" but inside "groups".
I thought about this, too, but in the evidence I did on my iam, it doesn't seem to be the cause.
Are you sure?
I have done other tests and eliminating only the main frame of my iam everything works (the series still there are all and in the deleted frame there are no mirrored elements but only mechanical machining )
No, the certainty not (in fact, I thought yes, but if you tell me that you tried and it is not that then no;) ).
I remember the same problem that happened a long time ago (I would say no more than a couple of weeks) and I solved by removing the series from the lowering of level... but then there was something else inside them...
I read you only now when I return to the office.:smile:
therefore:
Ilario's thought came to me, but the online guide says,
<<ristrutturazione ad="" all'interno="" altro.="" assieme="" assiemi="" assiemi:="" componenti="" componenti,="" da="" degli="" dei="" destinazione.="" di="" disporre="" e="" esistenti,="" file="" i="" incluse="" le="" lettura="" necessario="" o="" origine="" per="" più="" possibile="" privilegi="" scrittura="" serie="" spostare="" un="" uno="" è="">>
So it seems that you can also use the series, the mirrored sets does not talk about it, and cmq does not seem to have it.
And what is it?
I hope to solve it, because otherwise I have to hand out for a long time to create and win back the assemblies as I would.... .</ristrutturazione>
However, I tried to refurbish in a much smaller set, combining in a single subaxieme both mirrored axiemi and series axiemi.
It works here.
I am afraid that what sends in tilt the clone commander is the size of the assemblies to be restored.......:frown::frown:
No, it would be a halfway renovation.......... .
I only intend to try, isolate the problem and possibly add, after, those 2 or 300 pieces (:biggrin::biggrin: ) missing.
for what concerns the size of the set, on my iam, which is much smaller than yours, the operation ends or not if I remove or leave the main frame and only that.
Okay, the natives know three times il tempo e provo... .
but... before trying... but then how do I add the next pieces?
1 to 1 in the new set that creates me or is there any way to add them always with lower level?
once at a time, but think that luck if the lophy piece is one.
What machine and s.o. do you use to manage 4000 occasions?
I'll make you a proposal.
I never use the lower level, when I want to restructure a total I prefer to make a copy of components, both inside the same and in a new file.
This second type of copy could do for you.
Bye.
Have you tried to manually create a set inside a and then drag you into what you need? Maybe it works!
Then:
workstation hp xw6600
processor :1 x quad-core intel xeon processor e5420/ 2.50 ghz, 1333 mhz
hard disk 500 gb
ram 4 gb
video card nvidia picture fx1700 512mb pcie.
this regarding the pc.
as regards the method:
I tried with copying components but pulls out other problems, to say one, tells me that it can not create holes in a component etc....:confused:
so I renounced and refurbished cuff....:smile:
