luci with autocad 2009
  • Thread starter Thread starter ecomusposta
  • Tags Tags
    luci
ecomusposta
Hello everyone, premitting that I am not sure if my topic should be posted in this section or not, I have a small problem with autocad 2009.
I also press that I come from the use of autocad 2006, but for technical reasons the company imposed me to change method and graphic software using 2009. we go to the problem, I created a project of a very simple gear to start trying 2009, used in 2006 i.e. when I go to insert lights I put a simple spootlight and I created all the combinations of the possible lights, in 2009 I saw that the command is called reflector, but it goes well I thought the principle of operation I think it is identical, and instead I found some small problem, in the moment I go to make some reflection so settings from me inserted (which you can see also in the file from me attached) type of linear attenuation reverse, shadows on logically, white or similar light, beam of light 60 degrees because it is enough to me so (in the sense that it can illuminate all the scene). Now my question is what kind of problem persists in my design, and in case there was, what kind of mistake did I make?
waiting for a vs. I thank you in advance.
I attach the file. Hello everyone and good day.
Okay, sorry, I think I've solved, I've removed the attenuation and the unwanted color striscies have disappeared, but still the curiosity remains: ie on cad 2006 I put linear reverse, unless the spootlight and reflector are 2 things letterlamente and graphically different. now the last question before the moderators kill me, I noticed that the reflection of the shadows takes the color of the gear or better to say of the color of the reflex object, is there any commandment that allows me to transsfromarle to the natural?
