[machining] recover hole size
cacciatorino
I often have to add a hole to a piece, equal to an existing one on the same part. for now every time I input the data again, but would there be a way to withdraw the parameters (I apologize for the word) from an existing hole with a simple click and transfer them to the new one?
example: the laminated hole, for which every time I have to recompile the tabellina.
just select a similar hole ifa conn machining) that you also have on another model and then select the model face where you want to insert it, if that's what you mean
It's true, under the menu, there's the "copy" command I never used, perfect! :smile:
Sorry, but the system doesn't allow me to give you a reputation. . says I have to give it to other users before I can give it back to you, boh?!?
