Hi nicksoft,I didn't find anything. I know that the recorded macros are put here by I create when you change/save macros:
%appdata%\ptc\proengineer\wildfire\.wf\.settings\mapkeys.probut you will see that sooner or later they will make a sort of search_path that points directly to the personal macro file.
Yes ...in the text folder you must remember "export" and not save when changing a macro or creating a new one, while in the default folder you can simply use the "Save" commandmapkeys.pro is read from 2 locations : text folder and user profile as mentioned by @nicksoft
However, ptc would have had to run the new mapkeys.pro file in the same way as the ui file (the latter should be read by 3 locations. ..behave to improve.Yes ...in the text folder you must remember "export" and not save when changing a macro or creating a new one, while in the default folder you can simply use the "Save" command
