Leso
Hello, everyone.
premises: I had the need to automatically create x_t tube files starting from par and then use them for laser cutting.
to automate everything I created a macro that takes the pars of a folder and converts to x_t only those recognized as tubes.
in practice I created custom properties (width, height, thickness, tube [SI,NO]) within my files. the macro goes to see if there is the property "tubo"; if you go to see the size, create a folder "x_t" inside the par folder and then create a folder for each tube size.
I need you, I give you the source, and if you need me, you'll be fine.
I hope I'm useful to someone else.
p.s.: I tried to put various controls for crashes...but time is what it is. Take it "as is".
p.p.s.: to create the macro I fucked by the macro "batch" provided with it. I hope you can provide this modified version.
