Sp4rk0
Hello.
I wanted to know if there is a macro for measuring the angle between a segment and a plan, and copy the result on the excel file.
at the moment I use distance, select the plan and the segment and find the angle (23.1°), copy the result and copy it on a cell of an empty excel file, then do the same with the next segment, and so on, then I mix for example 30 angles one by one to generate the excel file, there is an automatism to do it automatically?
I would also like a macro that activated it would only make me the glue copy of the corner on an excel file.
For example
active macro
use measure, select plan and sketch, and the angle result copies it and pastes it automatically on the first blank cell of the excel file.
I know it's complicated but I can't get out of it, thank you.
For example
active macro
