macro for symbols insertion
gennarochiocca
Hello everyone, I am a novice of this forum. I need some suggestions.
objective : to realize a function that gives an external table in excel format, read the values of a column and insert in the drawing a symbol that has the same name as the value of the cell belonging to the read column.
I'll explain.
I have an excel file, the first column contains the cod.product of physical objects. Suppose it has 3 product cod.
e.g. ab-001, ab-002, ab-003.
the function I want to create inserts the symbols that I previously built with the names ab-001, ab-002, ab-003.
Thank you all.
p.s. : use autocad r14
with a macro is impossible, you can with programming (lisp, vba, .net, etc.).
If you really use the r14 maybe it remains only vba.
a quick (moderately) way is to export the excel column with data, in a csv file and then editing the file with the wordpad, turning the csv row sequence into a script file
In all cases if you really use r14, I wonder if there was excel for dos. I have no memory.
