macro "interrupt alignment section"
  • Thread starter Thread starter Sp4rk0
Sp4rk0
Good morning, I wanted to know if there is a macro that interrupts the alignment of the views in the section of several selected views.
I use many sections on the same design, if for example I have 20 sections in each section I have to use the command interrupt alignment, I would like to be able to select all sections and apply the command to all in one shot only.
I tried to record the macro while I do the operation but it does not work and gives me an error, I also tried to select all the views in sections and apply the command, but only apply the command to the first view selected and not to all.
I hope you understood my problem ..
should not disalline them to creation, while placing the view, using the ctrl key?
Oh, man, you know I didn't know this shortcut?
Thank you so much! would you also have a tip to create the section with a basic depth?
I do all sections with depth 200mm.
Thank you again!
Thank you again!
hi, no, for the depth, after placing the section, I go to activate the check and set the value in the proprety manager of the view. I don't know any faster methods.
