reggio
hi to all, in the previous episodes, I realized that, for my machines, the least worse way to simplify, lighten and hide the "secrets" before sending model to the customer is to use the hidden command joined to state of display.
as the operations are repetitive and monotonous, I put 2 buttons (hidden/show comp - exhibition comp hidden) in good view,
so I create new visualization status, name it, ctrl+a selections all, hid everything, show comp hidden, select the components to show, save as part, open part and save as step: ok it works, but remains monotonous ...
I thought I'd record a macro to run every time, so I could limit my intervention to the selection of parts to show and nothing else...
sin that the macro hide.swp memorizes, as well as the commands, even the names of the parts and the names of the files that save as part and as step, while I have the need to select by myself the parts to show and save by name that seems to me...
you would be able to guide me in changing this macro record so that after the macro launch do:- automatically creates new display status called "hidden" (always the same, I'm fine)
- Automatically select all that contained in the axieme (type ctrl+a)
- in automatic preme command hide/show components (to hide everything)
- automatic preme command shows hidden comp
- let me select all the components that I want and continues when I press "exci from exhibition-hidden"
- automatically returns to the previous display status (what shows everything)
- in car saves the axieme overwriting (I also save the new state but so that you see everything)
- in car returns to the display state called "hidden"
- automatically save by name as part (use the same file name but always in folder c:\buttami (of course not reactivating hidden or suspended parts)
- automatically opens the newly saved part file and saves it by name as step (use the same file name but always in the c:\buttami folder.
There's someone. (@jenuary @massivonweizen @...
) that could guide me in changing the macro attached?
so I create new visualization status, name it, ctrl+a selections all, hid everything, show comp hidden, select the components to show, save as part, open part and save as step: ok it works, but remains monotonous ...I thought I'd record a macro to run every time, so I could limit my intervention to the selection of parts to show and nothing else...
