make a mirrored part independent
  • Thread starter Thread starter paoanti
paoanti
as from title, maybe the question is stupid but I find myself having mirrored a piece that I thought was speculating but now going forward in the design, for a stupid thing, can not be speculate :mad: I tried by making "modification redefinition" on the feature of the mirrored piece but under independent options it is frozen and the only thing that is available is a command that is called "refraid ridatta" that I do not know what it is:
I thought I asked a trivial question... I didn't think it was so complicated.
I don't understand why it doesn't work. I did this and it works perfectly.
go to the model tree, right-click on the specular union>change definition and when you open the menu of the parent part go on options and remove the flag from "dependent".
That's what I did, but my problem and that the option is frozen... look at the image
Mah... from what I understood as the part is of sheet metal it is not possible to make an independent speculative copy, that is: if the particular source is a sheet cannot be independent, this is what I understood, although it seems strange to me :rolleyes:
I tried ... you can create it as independent, selecting "include all features" when you mirror the part, but once you created it as an employee, you can't go back.
:tongue: the fact and that it does not allow me to mirror with the option include features, telling me: "Impossible to mirror some features of this part" perhaps because I started from a solid then turned into sheet metal... Go to understand:
It makes me mirror it even from a solid. :smile:
a question so, just to understand, is not that you have external relations that the mirrored part cannot maintain?
What build are you using? I don’t want it to be a bug of a specific build.
I have wf4 m100 and this problem doesn't give me that.
more than other are external references.... then that's the problem:biggrin:
Wait, maybe it depends on the fact that the specchaire part was included in a subaxieme with the "restructure" command... cmq boh mo I am redesigning I have broken:finger:
