make an active layer from visual basic (not vba)
  • Thread starter Thread starter geogiac
geogiac
Hi...I try to do something very simple from visual basic (not vba) on autocad.. i.e. make a layer active........... .
for precision ..with this line of code ...
thisdrawing.activelayer = thisdrawing.layers("0")
I can in the autocad internal editor to make the layer "02 active............
.....I can't write the same on an external visual basic application.........
what I managed to do is
acad = getobject(, "autocad.application")
dim pippo as object
acad.activedocument.layers.item(0)
acad.activedocument.activelayer= pippo
I've always been wrong.... .
Help me!!? ? ?
non ho ambiente vb per provare, ma prova con
set thisdrawing=acad.activedocument
e poi con
dim pippo as acadlayer
set pippo=thisdrawing.layers.item("0")
thisdrawing.activelayer= pippo
Unfortunately in vb there is no acadlayer object (me by mistake) but I modified your suggestions in this way:
(by the way ....vb.net banalized the set)
dim thisdrawing as an object
dim a as object
thisdrawing = acad.activedocument
a = thisdrawing.layers.item("0")
thisdrawing.activelayer = a
it always gives me error on the last line.....(you don't recognize the member...!!!? ? ? ! ! ! )
Thanks anyway for the answer!!
dim a as object
If you don't leave, I suggest you pass the always trusted thisdrawing.sendcommand "_-layer" & vbcr & "_c" & vbcr "0"
method little fine but that at the moment unlocks you the problem !!!
Thank you so much....with this method it works.....I still have to manage the problem but in the meantime I can work... thank you again
In fact it must be a temporary thing, but the error I think is in some missing definition.. the same vba messed up if you misdefined an object even simply between object and entity... .
but can't you upload vba library references in vb.net?
dim acaddwg as object
dim dwg as acadapplication
set acaddwg = getobject("", "autocad.drawing")
set dwg = acaddwg.application
dwg.visible = true
set layer = dwg.activedocument.layers(0)
ricordati che devi aggiungere nei riferimenti del vb la libreria:
autocad 2010 type library
se usi la versione 2010.
bye
Remember that you have to add in the vb references the library:
if you use the 2010 version.
Are vba and thatel vb.net bookcases comatible?
Can you upload references?
I didn't propose because I thought they weren't compatible....
that I know, perfectly compatible.
Thanks... then this definitely changes the way to approach the .net... if you can use the vba libraries changes little way of programming right?
the problem however remains the same.... if they do not develop the libraries for new versions (as anticipated) this compatibility will be less and you will have to use the naked and raw .net to interface to autocad right?
an account is not to develop, another is to remove the vba form, it seems to me a gamble that not even the autodesk can afford.
Mr Bricscad, alternative cad, would become an even more valid alternative.
thanks to all for the answer.....I have not yet managed to find the solution to my problem ..........to make it worse I noticed that the workaround solution with send command only works with versions of autocad in Italian or English depending on the parameters turned!!!? ? ? ?
Well...
Well...
bhè this is a solvency problem always passing commands and parameters with the English version preceded by _
e.g. _layer & vbcr & _freeze (or _f) of course you have to know the commands in English but on the net you find everything.
