nf100 Guest Nov 17, 2015 #1 hi to all I have to make with inventor a drum cam similar to that of this video https://www.youtube.com/watch?v=kfgwjz4rwig?Thank you. steak
nf100 Guest Nov 17, 2015 #3 You're perfectly right. . How do I make a drum cam similar to that of the video?
TECNOMODEL Guest Nov 17, 2015 #4 the process is similar to that of the video, do a sketch in the floor, project it on the surface in a 3d sketch, do the sketch of the section and use it to make the sweep with which you cut the seat
Tarkus Guest Nov 17, 2015 #5 Sorry he, the procedure is the same as the video you posted. Can you ask where I find the commands equivalent to those used in the video in inventor?
