Teopado89
Good evening to all,
I'd like to ask if you can help me do the following:
I have a complete mold already shaped in catia.
I must create a "targhetta" (a kind of stylized representation) that will be attached to the mold that bears the following information:
a rectangle that is a stylized representation of the mold (then in scale and correct proportions), a shape of the piece that is printed (only the contour), and of the lines and circles that correspond respectively to the cooling circuit and the cooling wells.
These tags serve large lines operators to identify the mold, know what path does the given circuit, what connections do and so on.
Will you please help me find a quick way (less than a working day that is the current time) to be able to make the tag?
I attach a hand-made example of what I mean.
Thank you so much!! !
edit: the display should not necessarily be in the plant, say it depends on the cooling circuit because it must be as clear as possible.
