malfunctioning alias keyboard commands
  • Thread starter Thread starter Ilario
Ilario
hello boys, who does not die you see again:. . .
I have a problem, from the 2011 version onwards, with the keyboard shortcuts of inventor. assistance does not know and also on the autodesk site in English I read of others with the same problem but without any solution. . .
I try to ask you; I am a "adorator" for several years of the keyboard shortcuts of the commands, but it is a bit of versions to this part that "strip". some (especially those with ctrl+[Tasto], but not only, even the normal ones with the only button) just opened inventor work, but after a while (variable time, sometimes after 10 second sometimes after half an hour) do not work anymore. other i imposed them in the alias and after closing and reopening inventor are no longer assigned....this is what makes me mad because I prefer to have some keyboard commands rather than go to discard in the ribbon and then because I am now used for years to use the keyboard that sometimes I don't remember where the commands are...
have you or have you had the same problem?? and if yes, how did you solve it? ?
bye and thanks :wink:
