S.O.1212
Well I think the k of the rolling is different from the k of the bending so they are normal to have the possibility to use 2 k different because they are actually different.
then everything varies according to the material, to the radius of the fold blade, to the width of the matrix, to the bending system if in air, in support or in coniatura, to the direction of lamination of the sheet from which the piece is obtained.However, boys, maybe you lose yourself in a glass of water, at each processing you can give a different factor k desired --> explanation options --> explanation rules .. etc.
when you make such a narrow fold on a thickness of 3mm (half), there are many more fibers ironing than those that you buy. the neutra line moves towards the fold center and then k is small (0,33). vice versa when you calandra, also this thickness, with a wide radius, you can consider the compressed fibers, equal to those that iron, from here the k close to 0.5.hello excuse the question but why use 2k different? the value k on inventor is managed according to the thickness of the sheet that checks, having a unique thickness the k will be unique.
maybe you can get something going on set sheet values and varying values
no, you can't, it's incorrect, it doesn't create carding and it just creates confusion.another possible method is to find a medium k coefficient, of course calculating the percentage in a weighted way, i.e. how much they affect the lengths of the calandated part compared to the length of the two folded lembi.
as it has already been shown, for each fold you can attribute the k value you want!no, you can't, it's incorrect, it doesn't create carding and it just creates confusion.
But on the card you also put:no, you can't, it's incorrect, it doesn't create carding and it just creates confusion.
He's already given the answer to his question!I'm sorry if I interfere, but @s. 12.12 did not ask what must be and how to use factor k in reality, not even alternative solutions to calculate development; asked how to manage multiple values of factor k in inventor.
so you seem to me to be a request linked purely to the software settings.
everything written remains useful to the forum, but the main request that I imagine - I do not know inventor - has been recovered from @eugenesis.
It's fair to say that having initially posted the wrong section may have deceived the various users.
certainly pietro, but on the card or cartiglio, I also put the result of a practical test, which is and remains the best and most accurate solution to get what the designer wants.But on the card you also put:
type of blade.
type of matrix.
state of supply of sheet metal.
sense of lamination of the piece compared to the matrix.
working conditions ( bending in air - bending in support - coniatura )
and on the design indicate to each fold the coefficient k you attributed.
I made a rule with different k factors depending on the radius.Good morning to all, I hope to write in the right section.
I am struggling with a dilemma, I should make a sheet metal component, where there is both a downside and a fold as a result I would need to handle two different k things I have previously set up in the appropriate section.
only that since the surface and therefore the corner where I should bend is not parallel and the software does not bend me, and if I do it with the surfaces or with the contour flange does not bend me (bend). place an image here.
Has anyone found himself with my own problem yet?
Can you give me advice on how to handle this situation?
thanks in advance
actually the k of the bend is different from the k of the rollinghello excuse the question but why use 2k different? the value k on inventor is managed according to the thickness of the sheet that checks, having a unique thickness the k will be unique.
Thanks I am a little acerbo with the platesactually the k of the bend is different from the k of the rolling
the factor k does not depend on the thickness of the sheet, but on the relationship between the inner radius of fold and the thickness, Ir (internal connection) / mt (oftensor), something quite different.Thanks I am a little acerbo with the plates
