Riccardo_RDF
hi to all, it is not much that I use the cad blocks because I believed them not flexible, but reading on the forum I learned many things even if I have the ideas decidedly confused.
I understood how to use the command "Data extraction" to create a table inside the dwg for viewing and verifying the attributes of the various blocks.
if I have not understood badly this table is connected dynamically you have drawing blocks in fact if I change the attributes of the blocks then with a simple "update data table" you have alignment with the changes made.
However, I have not been able to understand whether it is possible to perform the reverse procedure, i.e. to make changes on the table that go to update the attributes of the blocks.
I hope I have been clear and I have not opened a useless discussion
