management blocks
  • Thread starter Thread starter Marco-92
Marco-92
hello to all, I have some problem with block management.
in a single file I created tables where valves are represented with editable labels and created them with the advanced block editor. And all right here.
only that if I have to take a valve from these tables, by copying and pasting it in another file it really puts us an eternity because it has inside a nested block called "genexeh". Does anyone know how to eliminate it?
or does anyone know how I can use for all files, these blocks that I created in one file?
ps. I tried to save with the name, delete everything and leave only the affected block, but by using it as a block on another side it does not make me change the value of the label, besides losing the base point that not even from the block editor I can restore.
Thank you very much in advance.
I tried to save with the name, delete everything and leave only the affected block, but by using it I put it as a lock on another side
means that you have the block inside a file and that when you insert block selections this file? in that case you are entering a block (the container dwg) which contains a block (your table) and these will not be editable until you explode the upper level block.
post the block that with a simple description is difficult to understand the problem
very good, so you do, you have to keep secret what was wrong and how you solve problems... and that we are here to give solutions to the first passing?
It was not my intention to create discomfort.
However I could not copy the blocks and paste them into other files because they were too heavy. so I used both the purge command that eliminated the blocks I used and then -scalelistedit doing the restoration. After these operations I could pick up the various blocks from the tables and import them to other files.
Although it is a problem limited to a specific situation it is always correct to report the possible solution.
