management boards impossible
  • Thread starter Thread starter strudeldemele
strudeldemele
hello to all
use sw2017 with ready2works. I'm having big problems working with the boards of assemblies: from 5mb up the table is unmanageable, only to view it and zoom it blocks half a minute each movement.
I managed to improve the thing by reporting to the default the property of the document (quote annotations etc.) but it is always impossible to manage....soever seen.
Can you help me? I have to deliver the job and I can't move on, so for a 3-hour table, I'll put a week and I won't finish it.
without knowing how the table is made and the model you can give the usual tips:
deactivate selection through transparency, view sena hidden entities, deactivate automatic view update, block view location, shade views on which you do not work
this to start
also make an assessment of the performance of both design and axieme to see critical issues
In fact I had already applied your advice but it seems there is some problem of settings that neither sw and ready technicians can solve.
If they give me permission to pass you one of the files with problems, could you give us an eye? And what am I supposed to do with you? Is the table enough to open with edraw?
if you have to pass the file you must pass the table and the part or together contained.
the editor is a viewer, you could possibly speculate about modeling issues, nothing more.
Did you do the function statistics?
