management codes
  • Thread starter Thread starter maior
maior
hello to all
I'd like to ask a question that maybe someone found an answer or a complaint.
is it possible in the same group to have reported with the same number balled two components between them interchangeable?
I make an example to simplify: I have two components of trade, for example screw a and screw b of two different but perfectly interchangeable suppliers.
I would like them to appear both in distinct base in the sense or mountains b with the same ball.
position 13 ----- screw at/vite b------q.ta' 1
I don't know if I was clear but thank you all
alessandro
firenze
No, you can't play the part.
you can change the iproperties of the object, or you can create an iassembly with the two configurations with however inside two distinct parts.
I for similar cases, put the double encoding divided by a hyproperties (the same field), so in the separate they both appear (the same box), and with a single "pallino", then who inserts the distinct in the management uses what it considers appropriate for production.
I hope I was useful!
