Bortoluzzi Gianluigi
Good morning, everyone.
I'm making projects that consist of a sheet metal frame. as a fastening system between the sheets I use very often tear rivets, while I use thread inserts (fixed on the sheet ) as anchor for brackets and removable components.
I wanted to manage rivets through the reuse library, such as screws and dice etc. giving my own code.
the problem is that each rivet has a closing range (thickness of the plates fixed together ) that varies from .. mm to .. mm creating a mountain of varied.
Do you have any tips to advise me to handle this in a simple way?
Thanks to everyone, good work.
