management of joint constraints
  • Thread starter Thread starter kipsing
kipsing
is it possible to make sure that under the parts that make up a set are only visible and only the three bearing constraints of that part?
There are cases where, for one reason or another, under one assembled part there are a sledge of constraints that are actually derived from other parts that are precisely aimed at this.
If there was a way to handle these constraints so that each assembled part would have only two or three direct constraints, that would be great.
even because most of the time it turns out a little hallucinating to try to distract each other's constraints.
you can only have 3 constraints for one part only if you bind each part to the geometries of origin of the axieme (something almost impossible if you have a set with+ of 2 parts)
you can give a custom name to each constraint by clicking the dx button on the name so you can identify it more easily.
other thing you can do is make visible the constraints that interest you
