management
  • Thread starter Thread starter edoitaly
if in the axieme depends on b and you want to have a coding of the 3 confiruzioni, you must have 3 of a and 3 of b and then bind every configuration of a to the correspondent of b. in the axieme you will have 3 configurations together with 3 codes at a time. all cascading and all tied up.
I confirm what written by mechanicsmg.
I attach files.
do so is simple, once you have the part that follows the changes of the axieme, create the variants in the axieme and each switch between the rmb confs on the component that varies in the context and use the command 'add configuration. . .
All clear, thank you.
I couldn't open it in your file because I work with sw2008 and you with a newer version but I already have a test set with "which depends on b" and I successfully applied your suggestion.
:) the important thing is to achieve the objective successfully:
