map or polysurfaces?
  • Thread starter Thread starter TOmmasoM
TOmmasoM
Hello
Help me that I've been batting the boss for five days.
I have the task of rendering a production (historical, current and future) of a company that makes silkscreens on glass. glass objects of different shapes have been purchased on which to apply serigraphs, and objects: vases, glasses, various containers have almost always forms traceable to trunkcons.
serigraphy is made exclusively on the external surface of the object.
I tried to create 3d objects by isolating external surfaces and applying graphics as a texture of the material. Unfortunately the graphics files (more than 400) have been realized according to the real production and then imagine that they are contained in an arc band (just like the development in plan of the outer surface of the truncated) and when I go to choose the cylindrical mapping on v-ray he applies it to me but I can not make coicidere the 2 ends of the circle arc band of the graphics.
after a few hundred years of evidence and seen a dozen tutorials I desiced not to rely more on the only rendering engine and I tried to make graphics as an object (polysuperfic):
Having the graphics also in vectors (.ai) I tried to make polysuperfici and then to "piegarle" but the polysuperfici bend in a non-omogeneous way (and they do a little gross).
I hope you understand the problem and that some of you know how to solve it... You'd save my life.
I attach a photo of an example of an object I have to replicate "the existence in 3d".
Bye tommaso
I think I understand your problem,
first solution
>... Unfortunately the graphics files (more than 400) have been realized according to the real production and then imagine that they are contained in an arc band (just like the development in plan of the outer surface of the truncated) and when I go to choose the cylindrical mapping on v-ray he applies it to me but I can not make coicidere the 2 ends of the arc band of the graphic circle.<<<<you have to change with a photo editing program graphic files maybe with photoshop take a portion of the decoration to be reproduced and with the edited command>transform>distorci or perspective suitable for your texture and make it flat and suitable for mapping
second solution
>> Having the graphics also in vectors (.ai) I tried to make polysuperficies and then to "piegarle" but the polysuperfici bend in a non-omogeneous way (and they do a little gross).<<<<you do not have to use the fold command of rhino but if you take your .ai and the command applies to the surface http://www.it.rhino3d.com/4/help/commands/applyobjectstosurfaces.htmI hope I've been helpful.
tree
Hello
Hello tree
thank you so much, your advices have been very helpful and have led me to solve the problem in this way:
I imported my .ai track of the graphics on rhino
I made a series of surfaces with closed graphics curves (actually what was colored sampling I made it a surface)
I applied the "curva" command by straightening the graphics (which as I told you I had as an arc band) on the floor. so I got a rectangular graphic area with the maintained proportions.
then I applied "appmeshuvn" and the game is done!! ! !
of course now I have to check some things and impose limits on the graphics on the superfice "guide" so that it is perfected but I know that you can do and with 5 commands I come to apply my graphics (also the most complex) to my 400 objects...... you saved me a year of work.... hello and thankseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ! ! !
