marcatura left
  • Thread starter Thread starter braunfish
braunfish
but does the score exist in inventor?
if I put a "fume" to one part in a sheet, in another sheet the same part has a different number.
So, on the same sheet (but also on different sheets) I would like to put the drawing together, plus the drawing of the individual parts that form it.
when I put the ball to the individual parts, the numbers do not correspond to those of the parts in the assemblies.
I think we've already talked about it.
Anyway, I'm going to do this.
do your overall views (plan-elevation-lateral )
when you want to put on the table the particular, you get the view that interests you from one of the main ones, on that obtained turn off everything except the piece you need, from this view you get the others related to the same detail.
do so also for other details.
is really slender, do first to force the number of the ball and the result is the same even if not automatic.
Bye.
If it's the same for you, you can set the ball in the editor with the indication of the part number and not the ether (default). in this way the ball marks each object with its number part and not with the number of the same in the part list.
when they stake the part however the choice option between part and item is stiff (not selectable) and unfortunately set to item.
you have to enter the style editor, in the "reference numbers" section on the right you will find "visualization of properties-choice property", select number part and add it after removing the existing properties, save and close.
Remember that if you want to make this setting common to other designs you must save the change to the style with the button close to the style editor.
to do this, however, you have to tell the project to be free in writing and not read alone.
