marking of parts
  • Thread starter Thread starter gecotec
gecotec
good morning to all I am a neophyte of the pro version, until now for the type of work I used the lt version therefore without assemblies now I am doing other works but I can not set the correct marking of the parts in the assemblies, I would like that within my carpentry file the program to name in the same way all the equal parts and that then these nomenclatures were the ones that I extrag in the distinct and distinct.
I don't know how to tell me a guide explaining how to deal with these issues?
Sorry but for the carpentry I usually use tekla structures and with inventor I make a little hard to gear. . .
If I understood correctly...
from the axieme launches the separate command part
view the fields file name and number partDISTINTA.webpof course the file names will be unique while the number part you can enter (and then copy-paste) the same code of the file together (welded shoe) so that, if in table 2d, your separate view the column "number part" ... the game is done; all details will have the same code
in case ... you do not understand, kindly if you attach a pdf or jpg of the result you want to get
We're about. .
I would need to get a distinct where every single piece of sheet, beam or piece has a unique number so that a shed is composed of elements all with a different number made except for those equal parts. . .
example:
part description n.° pz. lung. weight cad weight tot
1 hea140 2 4345 107 214
2 sheet sp 15 2 300 11 22
3 sheet sp. 8 12 250 0.5 3
here is a list of the kind where for example here are two columns composed by the same elements whose number part is unique even if it is two different models because then maybe on one I add a piece that on the other is not there and takes a new number of brand part 4.
basically I wanted to know if there is the finite model possibility to automatically rename all parts and the program associates names equal to equal parts or I have to do it manually to create the part with the name of the part.. .
Thank you and I hope I've been clearer even if I don't think :-)
