mass cartilage < > view
leggera
Good morning.
I put in the table a set and in the cartiglio appears the mass of the 1st positioned view.
Now I would like the mass to be referred to another view that is has another model state of the same table.
in a few words make the main view later.
Is this switch possible?
I create a new sheet - first copy the view I will determine as main (to which the table will refer) then in cascade I cover all other views. Finally I delete the sheet that I do not care.
excellent procedure thanks.
However it is strange that there is no possibility to change the main view or connect the mass to a chosen view.
having different views for different configurations in the same file can cause problems.
the right thing (in theory) would have n designs or sheets for n configurations
I also follow this procedure
