mass property
  • Thread starter Thread starter themole
themole
hello to all, I inserted the mass property inside the cartiglio but inserting a part always marks me 0 kg
How come?
so I can't explain. Surely it is wrong the parameter recalled, but if you post an example it would be easier.
the material (any one you use) you never have specific weight =0, unless it is modified.
I don't know what you use, but if you choose steel, it gives you the specific weight of steel, if you choose aluminum, the aluminum one. .
That's what I say. the specific weight always exists, so there is something wrong with the cartouche.
(question scema: did you put the cartiglio between the templates and then use that and put on the table a part? )
Maybe I'm wrong, but the material I decide when I play the part in ipt, then logically it brings it back to my drawing. .
pietro, you and I agree and we both work. a response from those who opened the discussion yesterday at 8:00 p.m. We'll wait till tomorrow morning to see if tonight at 8:00. . .
Sorry but I couldn't answer, I checked, the problem is not the cartiglio but I found that by associating with the part any material correctly associates it but in physical properties does not change the specific weight and the updated button is permanently off...bo
you have to update the mass in iproperties, or better yet, in the application options, general card, on the dx in half popping up updated physical properties during saving (parts and assemblies)
fixed there was casino in the material library displaying one with all weights specific to 0 and was selected.
