mass weight
  • Thread starter Thread starter alberto.castiglioni
alberto.castiglioni
Hello everyone
Today by making a calculation of the weights of a mechanical group there is a doubt and I would like you to confirm (or deny).
in physical analysis under the voice "mass" inventor gives me the weight or is it me?
exact, represents the weight
See, I'm drawing a tube1632998784970.webpthe weight corresponds to the commercial table
of the mass kg, of the weight n... , wanting to be precise is the catalog in error indicating "weight"... what is surreal?
I don't understand. in the catalog table of a tube or tubular or flat.... (extruded in general) the weight is expressed in kg per linear meter (kg/m)
In the sense that the mass is in kg, the weight force understood as mass * gravity acceleration in n: in fact on many lifting devices, to comply with the norms that indicate n as a force measurement unit (weight in our case), the dan appear that go to replace the kg. if you use the kg it would be correct to indicate linear _massa_, not _peso_ linear.
then in my experience the catalogs write that it weighs 2kg /m "because it has always written so and it's okay so", and where I work for example we would be in three to understand the difference
