Joshua662
Good morning boys
I have a problem with a very simple but very hostical product in its management, now I explain and hope to be clear in the explanation. we have a sandwich panel as in figure sandwich catia nativo First figure. This item consists of the following elements :
1) Upper sheet metal sheet
2) Bottom sheet
3) Insulating
this item for me is the master, "this term is for a panel with cutting measures that must at a later time have a threading and some processing". each single piece has the table with its own quotas always referred to the master. after glueing this master undergoes processing that are:
a) 2mm threading per side
b) holes
c) socket for supports
These processes must be visible only in the product and not in the individual parts, in order to overcome this problem I thought to use this procedure: the master save the stp and from them I go to perform the operations listed at point a,b and c so that they do not see in the parts of the master, but what happens? After putting in the table tells me to save components of my product step in catpart and if I don't do it at closing the drawing I lose the links to the product. I attach some pictures from the title:
i) sandwich stp
ii) closing of stp file with request to save subparts
iii) error and insulation seen placed at the table
I would like to know if there is another way to go to accomplish this work. in coclusion I would like to get:
a master with subparts with partnumber
the master must be transformed into a hybrid design that must be reworked "but these processes should not be present both in the 3d of the individual parts and in the relative masses in the table and in the master"
the table must be connected to the hybrid axieme. I remember that the sub-parts of this together do not have to be saved again because they would make copies of the same particular one with workmanship that belongs to the hybrid axieme and one without processing that belongs to the master axieme. I hope someone can help me in this situation I've lost my mind.
ps the last image is related to the table of the axieme stp after I closed everything and said no to the rescue of the individual parts of the image n°3.
2) Bottom sheet
3) Insulating
b) holes
i) sandwich stp
