mastercam x5; tplane,cplane ,wcs
  • Thread starter Thread starter maurice72
maurice72
I am beginning to put my hands on mastercam x5 and my first doubt concerns these mastercam functions, if someone could explain to me what is meant for every one of these 3 voices, thank you in advance to those who will answer me.
are the work plans....if you only use 3 axle machines and programs only in three axes leave them as you find them........... ! ! ! !
hi luigix, thanks x the answer , I wanted to ask you however how you can rotate the axle to perform a piece " in team " i.e. in the plan g18 second iso where the axis is y
see there are in the settings work plans.....now I don't remember well the name of the program as I almost never use it....work almost always in g17 and the plans g18 and g19 I use them only when I work in 3d to make the programs less long......cmq just tomorrow morning I open masteram I sign the menu!! !
hi I saw today, the work plans change down where you see the wcs writing click on and opens a drop down menu that shows you the plans....I recommend you work with collision control because it is a little more difficult than programming in g17.... and I am not even so hard on this type of work..... I am instructing! ! ! !
hello luigix thank you again, I just started with the mastercam so for me you are an expert! do you also have cnc heidenhain420/530? hello good weekend
on those controls I started my experience......beautiful machines!!!! !very versatile for programming on board machine the 530 is 5 axes?? ?no I'm sorry I work on fanuc now and think I arrange with generic posts, the company for which I work is tacky and nn wants to spend money so I have a little to arrange....!!! !
hi! start tomorrow to work in a small company that makes sheet molds, have two heidenhain 420 in operation to 3 axes plus another machine used to install where should be the 530 always to 3 axes , I have worked in the last years with the selca 4045 3assi + 1 of positioning , heidenhain I used very little the 530 aboard machine , a postp for mastercam x5 I would use.
Well if they want to work they will have to buy it a post-processor....for whatever you ask!!!! !
Hello, my name is roberto, I work on a fanuc series 31
I would like to manage the 4th axis with mastercam but I can't find any tutorials about it!
I can understand how!! you would be so kind to give me 2 straight on how to perform the procedure !!!
I've already created a .step file with solidworks but I don't understand how to give references !!!
Thank you in advance.
