material 38ncd4
  • Thread starter Thread starter world
Status
Not open for further replies.
what we are telling you, is that those data can be found alone with a simple google search.
still no data provided....only words
But you're joking, aren't you?
That's right!
but as you're a numb, and allow me the provocation, very unprofessional. . .
material quality 39nicrmo3 technical sheet
reference standard en 10083-3: 2006 trafilix
number 1.6510 light group
chemical composition
c%
max max
max max
max max
cr%
0.35-0,43 0,40 0.50-0,80 0.025 0,60-1,00 0.15-0,25 0,70-1,00
± 0.02 + 0.03 ± 0.04 + 0.005 + 0.005 ± 0.05 ± 0.03 ± 0.05
shocks admitted
for product analysis.
is also marketed with calcium treatment
can be supplied with added lead or controlled sulfur for improved mechanical processing
temperature in °C
deformation
warm
Tempering normalization
Tempra tempering disinfection
1100-900 860
air
850
Polymer oil
8.
water
550-650
air
50 under
temperature of
finding
reconstruction of
workmanship
reconstruction
isothermal
reconstruction
complete
tempering test
Jominy
preheat
for welding
Distress
after welding
300 550 Refr. oven
ac3 ms mf
700
air
(hb max 240)
820 Ref. oven
up to 650 then air
(hb 195-240)
820
air
(hb max 235)
850
water
740 790 330 110
mechanical and physical properties
hot rolled mechanical characteristics in reclaimed condition en 10083-3: 2006
traction test and resilience in longitudinal diameter /spess. at 20°C
mm r rp 0.2 to % c% kv hb
up to n/mmq. n/mmq. min. min. min. J min.
16/8 980-1180 785 11 40 - 295-354
16/8 40/20 930-1130 735 11 40 35 278-339
40/20 100/60 880-1080 685 12 45 40 263-327
100/60 160/100 830-980 635 12 50 40 249-295
160/100 250/160 740-880 540 13 50 40 224-263
table tempering values at room temperature on round ø 10 mm after tempering in oil at 850°c
hb -- 577 560 525 496 468 442 426 409 390 362 336 286 240
hrc - 56 55 53 51 49 47 45.5 44 42 39 36 30 22.5
r n/mmq -- 2160 2070 1950 1820 1700 1580 1500 1430 1340 1220 1100 950 800
rp 0.2 n/mmq -- 1440 1520 1540 1520 1490 1370 1290 1220 1110 980 830 670
10.7 10.8 11.0 11.5 12.5 13.8 16.0 19.0 22.0
C % - 30 42 48 52 53 54 55 56 57 60 63 68
kv j -- 28 31 32 28 28 27 28 36 46 86 114 128
rev. °C 50 100 150 200 250 300 350 400 450 500 550 600 650 700
39nicrmo3 1.6510 pren 10277-5: 2007 trafilix technical sheet
cutter +c +qt laminated ricotto balato +a +sh
(c)
mm r rp 0.2 to % hb r rp 0.2 to % hb
up to n/mmq n/mmq min n/mmq min n/mmq min min max
5 b) 10 -- -- -- -- -- -- --
10 16 -- -- -- -- -- -- --
16 40 930-1130 735 11 278-339 --
-- -- 240
63 100 880-1080 735 12 263-327
a) valid values also for smooth bald bald
b) for thicknesses less than 5 mm mechanical characteristics can be agreed in order phase
e) values valid also for rectified +sl
laminate reclaimed then drawn +qt +c laminated ricotto + trafilato +a +c
(c)
5 b) 10 980-1180 735 8 295-354 -- -- 295
10 930-1130 700 8 278-339 -- -- 290
-- -- 285
-- 280
63 100 880-1080 600 10 263-327
c) for dishes and special profiles the load rp 0.2 can differ of –10% and r of ± 10%
forged reclaimed uni 7874: 1979
diameter traction test and resilience at 20°c
mm r rp 0.2 a% l a% t kv l kv t h b
up to n/mmq n/mmq min min min min j min
100 880-1080 685 12 -- 40 -- 263-327
100 250 685-835 540 13 12 12 30 25 209-250
250 500 655-805 490 15 14 25 201-241
500 1000 635-785 440 16 15 25 -- 195-234
1000 590-740 390 15 14 25 -- 176-224
l = longitudinal t = tangential
en 10083-3: 2006 jominy hardening values in hrc (big grain g 5 minimum according to one 3245)
distance from the tempered end in mm
1.5 3 5 7 9 11 13 15 20 25 30 35 40 45 50
min 52 51 50 49 48 46 44 43 39 36 33 32 31 30 --
max 60 60 59 58 57 57 56 55 52 49 48 46 45 --
h
normal
temperature module elastic n/mmq rp 0.2 n/mmq thermal expansion density
tests at °C and long. g tang. . < 250 mm . 250-500 [(m/m●K) ●10-6 °C-1 ] kg/dm3
20 210000 80000 -- 11.2 7.80
europa en italia une spagna une germania din francia afnor uk b.s. svezia ss uses aisi/sae
-- 9840
copy-paste from the pdf you find attached and I hope you will get the trouble to download to consult it better. . .
I'm sorry, you know, if we were trying to make you realize that some "problems" can be solved by themselves... You're obviously used to finding the ready pipe.
better for you.. I hope you always have this luck.
if you want answers ready and complete you have to contact a paid service.
here each user helps a colleague if he wants it and if he has a specific computation on the subject.
to answer your question you have to do a google search, find a table and copy the data here on the forum.
It is an alvour that does not require any particular competence but a discrete loss of time (not paid) and so you can do well alone. That's what you got.
exhausted argument and given and exhaustive answers, if you can't read or use google... I'm sorry for you....
Lock and stop.
Status
