ossosso
Hello!
I'm going out crazy... I've attached the family of a window door found on the web.
I would like to change the color of the various components (fixed, Persian, frame. . )
after placing the family in my project the select-->edit type--> there is a tab that is called "material and finishes" in which in theory I can change the materials, but while inserting a different material in one of the fields, the graphic result monitor (but also in rendering) does not change of a comma, only for the shutters, but for the rest not.
Where's the hippo?
Thank you so much!
Where's the hippo?
Thank you so much!
