material definitions on section/prospect 2d
  • Thread starter Thread starter danix
danix
wishes for everything and for everyone!do you know when you make a nice 3d model with all the silky materials and want to pull out a nice section?
Good. .
1 - I set all the representations of aec materials present in the 3d model...
2 - I have generated a 2d section that takes into account the "definitions of materials". . .
3 - here is the "freshing"... the section is created in part... I'll explain. some lines and restraints (which should come from the difinitions of materials) are drawn other ignored... result: an incomplete 2d section and to remake.
I solved but in part.. .
I practically deactivated the "material definitions", no longer enjoying its privileges!
I took off the tick in "representation 1:100" for "material definitions" in the display group referred to in section 2d (in my case it was section 3d), leaving all the representations active for "model 1:100". . .
the result is a worthy section that takes into account all the components of the model... the only flaw is that you do not have all the settings of the materials (including section). .
Why can't aca generate a section with the materials set up properly?
I would point out that I checked and rechecked the options "excluding the continuous contrno...", "unisci materiali comune"... layer, hold, etc... in all the materials present in the scene.
I trust you...
Happy birthday!
I changed pc...
I did a couple of tests (on single file). . .
Everything works.. .
What?
