Tuli
Hello.
I have a problem with modeling a part of the sheet that I can't fix. . .
basically, I should make a revolution on the part by eliminating material.
Unfortunately the option eliminates material is not available by making a revolution on a sheet.
I also tried to make the revolution before converting the part into sheet metal, but doing so I can no longer convert the part.
to be clearer, please attach the model in question.
In practice I should use the sketch called "cut" with the axis called "cutting" to remove material from the side.
Can someone help me?
thanks for the attention.
