material: error display in combination
  • Thread starter Thread starter pasquale83
pasquale83
:confused:
I have a set of about 100 parts divided into sub-axioms, partly in sheet metal and partly in glass,
the problem is that some parts are displayed without material,
but opening the individual parts you see that the material is properly assigned
and display is characterized according to the material. . so it should be all right
Why do you give me this mistake? have you found this problem in the past?
precise that initially I had not assigned the materials, only subsequently I modified the parts by adding the material,
But I tried to rebuild and save... But nothing... the display error remains:
It can happen that in the axieme, but also in the part, there is some color that covers others. I imagine that having assigned back material has its influence.
in these cases you have to open the card display manager and understand which one should be deleted. It's not easy if there are so many.
to scan of problems it is best to make a screenshot of the card and print it, save the axieme and proceed, with the press to delete with the calm and method marking which you and what not. is of help the fact that the colors of the materials are well defined (clear glass, steel, wood,...) while the generic ones, perhaps inherited from the creation of the part without material, have name color That's enough.
