material for swine turbines with variable geometry
  • Thread starter Thread starter D.Sciortino
I have a problem with the loft commandlooking at the example 1 I have to run with the loft command the fin of the impeller of a turbine. I did the sketches 1 and 2 and the relative guide curves, the problem is that with loft it does not want to perform (with surface loft instead si) . I tried to change the guide curves , I removed them, put for each sketch summit but do not want to know to do so. then I did a test by doing the sketches of example 2....and can't do this neache!! If I try to open a new document instead and do a sketch similar to example 2 does it naturally without problems, even without guide curves
But if you don't tell us what software you're doing?? ?
If you have to ask about the software better to post on the appropriate section, don't you think?
I had specified at the beginning thread the use of solidworks. however placed in the special section.
