material quantities of scales
  • Thread starter Thread starter lorenzo67
lorenzo67
good day to all, using the abacus of the stairs, I would like to extrapolate the quantity of materials used (e.g. concrete of the steps, sunburns and landings, coatings etc.). the problem is that I can't extrapolate all the dimensions of the stairs like the length and width of the ramps, dimensions of the landings etc.
thanks in advance, very kind
I think it is possible to get most of these things, not all, with abacs. look at this example:
Also, you can use an abacus of quantity of materials, if the surfaces are painted:
thanks for the suggestion, those data I extracted too.
sincerely I would need the length of the ramps and its thickness, the surface of the landings etc., so as to calculate also the surfaces of the crates.however very kind
all the supercies can be obtained by pushing them with a material, and then using the abacus to see the area.
