materials imported in autocad 2011
  • Thread starter Thread starter Shape
Shape
I often carry 3d drawings made with previous versions of autocad (from me) and almost 100% of the cases the mapping of the materials is high, firstly due to the lack of the value suitable to gizmo and vabbè, however I also get the scale values where set and the strange thing is that to get the medes results I have to multiply them for about 100/1000 times compared to the value that was set.
Is this behavior normal?
Moreover this thing is strange because using the realistic view that shows the mappings the display in the import is ok while in the render is wrong, when I correct the values on the render are ok while in visualization are huge.... .
hi shape, sometimes the opposite happens to me, that is I see them wrong in realistic but then in making they are correct.
stupid and discounted question: is the unit of measurement of the various designs always the same? have you verified that it is not modified?
Hello, Steve. sometimes they come back you have seen!!!
I didn't notice why being already set up in the creation phase should be the same.. because they are drawings that I had made with previous versions open and I ran the error...today I verify. .
