tecnico_plast
the occupied volume is the same, but the use of the round wire involves the existence of the voids, therefore in reality the volume is smaller and therefore also the length, hence the need for the correction factor for the round section regarding the square one, and in addition you should consider a factor for the empty ones.
the use of conical threads in fishing is really very limited, and if ever using conical wires, they are conical only in the last meters (a dozen), influential than the large amount of wire wrapped in the coil.
