mating problem with guide.
  • Thread starter Thread starter matteos
matteos
Hello everyone, I am creating an opening system through hydraulic piston (as seen in the photo). I should try to simulate the movement in the "movement study" in solidwork 2011, only that I can't find the right driving couplings (circled in red). in practice the bulkhead, lifted by the piston, should first move vertically and then follow the path of the guide...and then arrived at the end of the race should rotate. how can I give this end of the race?
Thank you very much for your help!
I see a pin inside an asola and if you want to limit the movement of the pin inside that asola put a limit distance bond between the axis of the pin and the axis of the two rays of the asola and then make the axis of the pin coincident with the average plane of the asola. When the pin arrives at the end of the race in the asola it will be behind the rest of the acrocco according to the degrees of freedom you left.
It's actually a sunbathing. I thank you for the help I will try to put into practice what you tell me..(if I can) :)
