mating problem
  • Thread starter Thread starter elpado6872
elpado6872
Hello everyone I am a student of ing. mechanics and I would have a question to ask for a coupling in a set of solidworks. I attach two images to better make you understand what kind of mating I can't do.
as you can see in the image called "internal patisse.jpg" I have a yellow shoe to which I would like to prevent getting out of gray support. I have inserted a mechanical coupling of type screw so turning the right hand crank, however, I would like to insert a kind of "limit" coupling that does not happen the situation of the image "pattinouscito.jpg" when I turn the crank or I draw the skating with the mouse. if all this is possible I ask if someone can explain how to do it. Thank you all!
I haven't done this sincerely, but try to look at this. I'll try to make it myself if you can't!
http://help.solidworks.com/2011/ita...ks/legacyhelp/sldworks/assem_1/screw_mate.htm
...I would like to insert some sort of "limit" mating. . .
you have to add a couple distance limit, found among the advanced couplings.
do the tutorials, follow the help and guide online that is all ruthless.
Mar
p.s. and insert images using the appropriate forum tool for attachment management (you find it in the same place where you write the message.. look around).
