maximum size of a component
  • Thread starter Thread starter slymer
slymer
Hello everyone, reading a report on the modeling of a support bracket, the author of the document inserted an image in which the bracket is displayed with around a translucency rectangle showing the maximum size of the component. from here, I wanted to know if any of you can tell me how to view this type of measure.
thanks in advance for the help.
Greetings, silvio.
Could you post the link to the image? At least let's see better than what it is.
Thank you
Greetings, silvio.
nx does not (unfortunately) that type of measurement with a specific command, unless you have the package for moldwizards.
I think the image was "built" like this one that I train you.
Thank you, that's her. So it was first built the piece and then later, who made it, with holy patience drew a solid to its outline, made it translucent and then measured the sides with respect to the wcs flegging in the measuring options to remain the result to video ... right? ?
Thanks again...
Thanks again...
I would say no: many cads make a representation of the box of maximum dimensions, as seen in the image. in a single command
with nx there is no function that provides the maximum size and represents it for printing in a simple and immediate way.
...at least as far as I know.
there is a function in the Moldovaw package, I think ciciu refers to that to create a box around selected geometries.
But don't put the odds, you have to put them.
