shadowmyth
Good evening,
we have recently updated autocad to 2019, but I can no longer measure the angles properly. I'll explain better. first with autocad 2012 I select the lines that composed the corner and depending on where I positioned the cursor measured the inner corner to the lines or the outer corner. Forgive the imprecision of language, but I think we can understand. I can now:
1) to measure the internal angle (image 1)
2) to measure the outer angle forming between one side and the extension of the other (image 2)
3) to measure the opposite angle to the inner corner, so the angle itself, taken on the extension of the sides (image 3)
I can no longer measure the outer corner at least that does not make a circle, cuts and selects the outer arc with the measuring command. Could someone help me and tell me how I can go back to measuring the outer corner?
