Dr.Lube
hello to all, I renew a request made a little time ago (updated to the current situation).
I would have to measure the length of a polyline between two lines that I insert.
polylinea to measure comes from a block (you could explode and make a undo? )
How can you do not by hand?
by hand I would explode the block and make a size so that I only remain the part between the two lines. .
Thank you so much!
dennis
How can you do not by hand?by hand I would explode the block and make a size so that I only remain the part between the two lines. .
Thank you so much!
dennis
