mandoline Guest Jun 28, 2011 #1 Hello everyone.. I wanted to ask for advice... use from very little rhino.. I opened a file that I downloaded, this is in mm and I wanted to ask you how I could do to turn it into m... thank you:finger:
Il marangon Guest Jun 29, 2011 #2 if you go on document property, drive you can choose what to use, mm cm mt etc...
mandoline Guest Jun 29, 2011 #3 Il marangon said: if you go on document property, drive you can choose what to use, mm cm mt etc... Click to expand... thanks for the answer... Now I try!! because I imported a .3ds file but this is in mm... now I try!!
